ipNetmask | Specifies an IP address/mask length. |
ipaddress | Specifies an IP address. |
mask | Specifies a subnet mask. |
gateway | Specifies a VLAN gateway. |
multicast | Specifies a multicast route to delete. |
multicast-only | Specifies a multicast route to delete. |
unicast | Specifies a unicast route to delete. |
unicast-only | Specifies a unicast route to delete. |
vlan | Specifies the egress VLAN name used for an Inter-VR route. |
vrname | Specifies the virtual router to which the route is deleted. |
If you do not specify a virtual router, the current virtual router context is used.
Use a value of 255.255.255.255 or /32 for mask to indicate a host entry.
The following example deletes an address from the multicast routing table:
configure iproute delete 10.101.0.0/24 10.101.0.1 multicast
The multicast and unicast keywords were first available in ExtremeXOS 12.1. These keywords replace multicast-only and unicast-only, which remain in the software for backward compatibility.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
